MySQL database faulted!
Hi guys!
My database connection is faulted. It never worked. I am attaching the error details. Any suggestions please !
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:242)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:196)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer$1.run(DatasourceManagerImpl.java:1014)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.sql.SQLException: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1074)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:988)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:974)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:919)
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1062)
at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3556)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2513)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)
at com.mysql.jdbc.ConnectionImpl.(ConnectionImpl.java:822)
at com.mysql.jdbc.JDBC4Connection.(JDBC4Connection.java:47)
at sun.reflect.GeneratedConstructorAccessor47.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
… 12 more
Caused by: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1007)
… 27 more
7.9.8 (b2018053113)
Oracle Corporation 1.8.0_171
Are you using the newest version of the connector?
Yes, I believe this is the newest version.
This is the message in details-
Databases / Connection [MySQL]
And he connector- mysql-connector-java-5.1.23-bin.jar
Which version of MySQL Server are you trying to connect to?
Its version 8.0.11. Also, I’m using Mac if that creates any difference. Thanks
You'll need an updated JDBC driver and some extra connection properties:
Hi Kevin, thanks for the suggestion. But I am still not able to connect the database.
uninstall version 8.0.1 completely and delete any left over files and folders. Install 5.7.x. It will work perfectly.
Can confirm, above solution by @R.Alamsha works
