Has anyone tried running MySQL outside of the Ignition gateway? I’m curious to know what the drawbacks are of running MySQL on another server or in a hosted environment.
We want to be scalable to run multiple projects and I can see how having several schemas with several projects all on the same Ignition gateway could get to be a difficult task to manage. Thanks in advance for your input.
Most of our customers use a database that is on a different machine. We recommend that so the database can use dedicated machine resources. There aren’t any drawbacks.
After speaking more with Rackspace about the “cloud database” option; we won’t have root priviliges to the DB and won’t be able to edit the .cnf file. Would this be a problem?
I don’t think so. Ignition needs full privileges on the database to create tables, query, insert, update, and delete. As long as you have that it should be fine.
