Hi, I’m not much of a ninja on exception handling in general. In this case I’m trying to gracefully handle a duplicate constraint exception. Currently I’m just trying to capture it with a generic Exception handler, but it still raises the error, and ignores my code to pop-up a message box instead.
Here is the exception with query details ommitted:
Traceback (most recent call last): File “event:actionPerformed”, line 20, in
_ File “event:actionPerformed”, line 20, in _ java.lang.Exception: java.lang.Exception: Error executing …
_ caused by Exception: Error executing system.db.runPrepUpdate…_
_ caused by GatewayException: SQL error for …_ Duplicate entry ‘1234-5-7’ for key ‘unq_partno_locationid’
_ caused by MySQLIntegrityConstraintViolationException: Duplicate entry ‘1234-5-7’ for key ‘unq_partno_locationid’_
In jython, except clauses can specify java exception types in addition to python exceptions. Use something like this:
import java.lang.Exception
try:
# some code that can throw a non-python exception
except java.lang.Exception, e1:
# Handle the java exception
except:
# Handle any other exception
The try never catches the exception and runs the message box code. It always raises the exception in the ignition error popup. Regardless of what type of exception I look for.
Follow my instructions. Python defines it’s own Exception datatype, and only catches that and its subclasses by default. To catch non-python exceptions, you must explicit catch java.lang.Exception.
Sorry, I breezed right past your post and clearly didn’t pick up on the pertinent details. That is working and now I get the difference with the types of exceptions. Cheers!
