MySQL Not Updating
I am having troubles with changing a value in table to update MySQL. I run the following cellEdited script. It will look like it takes after I hit enter. However, after a few seconds it will change back and not update MySQL table to reflect the change I want. I don't get any errors and database table is correct. (test_locationn). I am trying to change Completed column and specific row from "N" to "Y". Thank you for any help.
Completed = event.source.data.getValueAt(event.source.selectedRow, 'completed')
headers = system.dataset.getColumnHeaders(event.source.data)
query = "UPDATE test_locationn SET %s = ? WHERE Completed = ?" %(headers[event.column])
args = [event.newValue, Completed]
system.db.runPrepUpdate(query, args)
Try adding a refresh:
system.db.refresh(event.source, "data")
I have added that and it won't even look like it is trying to take. I just switches back to "N" Right Away
Does running the query directly in MySQL Workbench work? Perhaps there's a trigger you're unaware of that is setting the value back AFTER UPDATE or something.
I entered this into my MySQL and worked:
UPDATE test_locationn SET Completed = 'Y' Where ndx = 47;
It is updating in MySQL but still not on Ignition.
Your original query is WHERE completed not WHERE ndx
Did you try @JordanCClark's suggestion?
What does the binding on the table look like? Is polling set up or is it just static?
