We are setting up ignition critical with mysql multimaster replication.
My question here is would it be possible to monitor the replication within a project?
Somehow one could have a plugin in ignition that could be used to display the replication status on a page.
Has any one done this? Any help would be appreciated.
We we had to monitor a replication to ensure it wasn’t falling behind, we created a table with one record in the source db and a process then updated the time in that record.
In the replicated db we polled that record and compared it with the current time. If it was to old we sent alerts to the sysadmin.
Thanks Travis. It’s being a few years since I’ve played with MySql.
Travis’s is the correct way to know if something is broken. We didn’t use it because it doesn’t tell you if it’s keeping up. In our case we had a time critical SLA and an application that tending to flood the replication link.
On the master database box we created a cron job that ran every minute, connected to the db and ran:
update HEARTBEAT set LASTTIME = NOW();
On the slave database box the cron job ran something like:
select NOW() - LASTTIME from HEARTBEAT;
If this time was greater then the limit raise the alarm.
HEARTBEAT is a table with one record
LASTTIME is a timestamp column in that record
NOW() is the function to return the current timestamp.
Like I said, it’s being a few years so the SQL above my have to be tweaked.
Thanks for all your help, great stuff. I am sorry if this appears to be a stupid question but i am all new to this.
How could i get this information into ignition and display it?
Lets say i want to display the information on a client screen:
Master_Host: ‘IPaddress’
Slave_IO_Running: Yes
Slave_SQL_Running:Yes
Furthermore generate an alarm if Slave IO or Slave SQL are not running.
The general idea would be to run a query that got you the status you needed, and then put that query into a SQL Query binding on a label in a window. If you can’t formulate a query that returns the exact result you want, you may need to write a Python script to manipulate some query results to format the information you want, and then stick it into a Label in the script.
When i use the SQL Query Browser in Ignition and use the Command show slave status, with or with out the delimiter \G i don’t get a result back at all. Resultset 1 = Rows -1
However if i use the same command in the mysql command prompt in windows i do get a result as per travis.cox’s post.
MY question is, how do i extract the fields:
Slave_SQL_Running: Yes
out of the result set that is generated out of the above expression.
Furthermore, how would i get those two Fields into a Database Table called “MySQLRep” and update the table periodically, say every 1 minute?
I presume i use a gateway timer script. However as i said i am stuck on extracting the data out of the result set. T
his would then allow me to view the data on the client and generate an alarm in Ignition etc.
Thanks again everyone for your help.
Regards
Sascha
You can add two dynamic properties to your table (Slave_IO_Running and Slave_SQL_Running), and then use expression bindings to grab the data you want for each. ie:{Root Container.Table.data}[0,"Slave_IO_Running"]To avoid any errors caused by the table being empty, you will have to check the dataset length first.if(len({Root Container.Table.data})>0,
{Root Container.Table.data}[0,"Slave_IO_Running"],
"n/a") Once you have the data in these two properties, you can make a propertyChange event script that writes these values back to your database whenever they change.
Hi Colby,
i need this to be able to update when there is no client active, as this application may not be viewed all the time.
Will i be able to do this with the above in mind?
MySQL Replication monitoring script:
It gets the querry of SHOW SLAVE STATUS, then finds the COLUMS required for my monitoring database table and inserts the values into the table "mysqlreplication " with a current timestamp for later analysing in the client/gateway.
hope this helps others
def mySQLReplicationStatus():
import system
#variables
dataset = system.db.runQuery("SHOW SLAVE STATUS","YOUDATABASECONNECTIONNAME")
#Check that there is records in the dataset
if len(dataset)>0 :
for rows in range(len(dataset)):
#This will get the words as a list of strings
Column = dataset[rows]
#Check if there is a record in this row
if len(Column) > 0:
#print "Master_Host: Slave_IO_Running: Slave_SQL_Running: Seconds_Behind_Master"
#print "%s \t %s \t\t %s \t\t %s" % (Column["Master_Host"],Column["Slave_IO_Running"],Column["Slave_SQL_Running"],Column["Seconds_Behind_Master"])
#for cols in range(len(Column)):
# print "Col %s: %s" % (cols,Column[cols])
#Write Values to DB
system.db.runUpdateQuery("INSERT INTO mysqlreplication (Master_Host,Slave_IO_Running,Slave_SQL_Running,Seconds_Behind_Master,t_stamp) VALUES (\'%s\',\'%s\',\'%s\',%s,NOW())" % (Column["Master_Host"],Column["Slave_IO_Running"],Column["Slave_SQL_Running"],Column["Seconds_Behind_Master"]))
return 1
