Hi, I have a problem when I try to get data from a mysql db, I have this table :
CREATE TABLE `events_table` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`date` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
`id_tag` int(11) NOT NULL,
`value` int(11) NOT NULL,
PRIMARY KEY (`id`),
KEY `date` (`date`)
) ENGINE=InnoDB AUTO_INCREMENT=1683945 DEFAULT CHARSET=latin1;
I have multiple tags with a value changed event, when this tags change the value, insert data to my table.
In one hour I get 120.000 records, so when I try to get this data to a table component in igntion I get a query that last 10 seconds, is this normal for the for the large amount of data?
[quote=“MoisesZV”]Edit: Now it’s freeze again.[/quote]I’m curious if you can connect to ignition, the database, or the OS from another machine while it appears to be frozen. Please turn on “Debug” logging for the AbstractCache class. Then send your logs to
