Hello,
Can someone guide me on using If Else statement in where clause in MySQL query?
This is what I want to do:
distinct(op.Name), ro.PredictedValue, ro.TargetValue, sops.ActualValue
FROM outputcomponents oc
JOIN runoutputs ro ON ro.SubComponentID = oc.ID
JOIN outputs op ON op.ID = oc.OutputID
JOIN sendoutputs sops ON ro.SubComponentID = sops.SubComponentID
WHERE (
IF (SELECT count(SendDataID) from sendoutputs where RunID = 257) > 0)
THEN (ro.RunID = 257 and sops.SendDataID in (SELECT max(SendDataID) from sendoutputs where RunID = 257))
ELSE (ro.RunID = 257)
Order by oc.OutputID
But I get a MySQL syntax error when I try that. What is the correct syntax to add If Then Else condition in Where statement?
Thanks,
Shreyas
