I am trying to make a time clock within Ignition. I have a table that stores the employee clock number and the time they punch in, and the time they punch out. I am trying to get the difference in hours:minutes:seconds between these two fields.
I have looked at :
Datediff()
Datesub()
SubTime()
And I can not get it to work. Do those values have to be converted to subtract out?
create view punchclock
as select id_employee, clockin, clockout, SEC_TO_TIME(TIMESTAMPDIFF(SECOND,clockin,clockout)) as mytime
from tbl_timeclock
where clockout is not null
It returned output formatted like this:
1970-01-01 01:21:34
So I tryed this:
as select id_employee, clockin, clockout, DATE_FORMAT(SEC_TO_TIME(TIMESTAMPDIFF(SECOND,clockin,clockout)),'%H:%i:%s') as mytime
from tbl_timeclock
My column is set to allow nulls, with default null.
The above example code was ran against the same data with those results. I am confused how it could calculate with the first code and show nulls in the second.
The problem is because you are using a view. If you take that query out of the view and just run it the results should be just fine. However, the view is taking the final result thinking it is a date but it is a string. So in the view you can cast it to a string:create view punchclock
as select id_employee, clockin, clockout, CAST(SEC_TO_TIME(TIMESTAMPDIFF(SECOND,clockin,clockout)) as CHAR) as mytime
from tbl_timeclock
You could try using TIMEDIFF(), it returns the results in the format you’re looking for, makes the query easier to read. Works on time and date-time values, both values have to be the same type.
