I have created one report where I have used the @total.value@ function in the summary band of a table where the column data type is ‘Double’. This works beautifully.
On another report I have tried to do the same thing. The column is also of type ‘Double’. In this case, the report displays where the Total is supposed to be.
Do you have the DataSet Key entered for your table? Try displaying a single column in your table to see if the data is properly linked. If you don’t have the key:
Select the table object
Look for a value under DataSet Key. In this screenshot it’s called Data.
If blank, either type the name, or drag the dataSet from your keys above
