I’ve started using Named Queries and I LOVE them.
Is there a way to trap the errors, for example:
Unique Key violated
Parent Key not found
Insufficient Privileges
etc.
I’m using a try/except block like this:
try:
runNamedQuery( ‘myQueryName’, {‘partNumber’:pn,‘lotNumber’:lot} )
except:
logger.error(‘myQueryName failed…’)
but I would like to capture a meaningful message vs. “something went wrong.”
bfuson
January 31, 2018, 7:14pm
2
Does this work for you?:
import sys try: results = system.db.runNamedQuery("queryName") except:Preformatted text logger.error('queryName failed' + sys.exc_info()[1])
sys.exc_info()[0] contains the type of the error and [1] contains the message afaik.
edit: Forgot the import statement at the top. Couldn't format the indentation either...
Yes, that’s exactly what I needed.
Had to add “import sys” at the beginning of my script and it works like a charm.
Thank You
