Hi, working on a customers system that originally did not have partitioning setup for the Historical Tag Provider. Over a year ago partitioning was enabled and set to monthly partitioning. Ever since that change was made, the named queries stopped working for any date range set after the day partitioning was enabled.
Is there a way to change the named query below to look across multiple tables?
SELECT
-- The record's timestamp is the earliest timestamp of all the tests available
LEAST(cfe_s, clearwell_s, low_cl_s, fb1_s, fb2_s, fb3_s, fb4_s, fb5_s, fb6_s, fb7_s, fb8_s) date_time,
-- The test results
cfe_s, cfe_sv, cfe_sp, cfe_pass,
clearwell_s, clearwell_sv, clearwell_sp, clearwell_pass,
low_cl_s, low_cl_sv, low_cl_sp, low_cl_pass,
fb1_s, fb1_sv, fb1_sp, fb1_pass,
fb2_s, fb2_sv, fb2_sp, fb2_pass,
fb3_s, fb3_sv, fb3_sp, fb3_pass,
fb4_s, fb4_sv, fb4_sp, fb4_pass,
fb5_s, fb5_sv, fb5_sp, fb5_pass,
fb6_s, fb6_sv, fb6_sp, fb6_pass,
fb7_s, fb7_sv, fb7_sp, fb7_pass,
fb8_s, fb8_sv, fb8_sp, fb8_pass
FROM (
-- CFE
(WITH vals AS (
SELECT
to_timestamp(t_stamp / 1000) cfe_s,
(SELECT floatvalue FROM get_tag_data('filter plant/cfe/turbidity', NULL, _d.t_stamp, false, 1)) cfe_sv,
(SELECT floatvalue FROM get_tag_data('filter plant/cfe/set points/turbidity high/alarm', NULL, _d.t_stamp, false, 1)) cfe_sp
FROM get_tag_data('filter plant/cfe/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/cfe/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
cfe_s, cfe_sv, cfe_sp, (cfe_sv >= cfe_sp) cfe_pass,
-- Provide the column names for the other tests here
NULL::TIMESTAMP WITH TIME ZONE clearwell_s, NULL::DOUBLE PRECISION clearwell_sv, NULL::DOUBLE PRECISION clearwell_sp, NULL::BOOLEAN clearwell_pass,
NULL::TIMESTAMP WITH TIME ZONE low_cl_s, NULL::DOUBLE PRECISION low_cl_sv, NULL::DOUBLE PRECISION low_cl_sp, NULL::BOOLEAN low_cl_pass,
NULL::TIMESTAMP WITH TIME ZONE fb1_s, NULL::DOUBLE PRECISION fb1_sv, NULL::DOUBLE PRECISION fb1_sp, NULL::BOOLEAN fb1_pass,
NULL::TIMESTAMP WITH TIME ZONE fb2_s, NULL::DOUBLE PRECISION fb2_sv, NULL::DOUBLE PRECISION fb2_sp, NULL::BOOLEAN fb2_pass,
NULL::TIMESTAMP WITH TIME ZONE fb3_s, NULL::DOUBLE PRECISION fb3_sv, NULL::DOUBLE PRECISION fb3_sp, NULL::BOOLEAN fb3_pass,
NULL::TIMESTAMP WITH TIME ZONE fb4_s, NULL::DOUBLE PRECISION fb4_sv, NULL::DOUBLE PRECISION fb4_sp, NULL::BOOLEAN fb4_pass,
NULL::TIMESTAMP WITH TIME ZONE fb5_s, NULL::DOUBLE PRECISION fb5_sv, NULL::DOUBLE PRECISION fb5_sp, NULL::BOOLEAN fb5_pass,
NULL::TIMESTAMP WITH TIME ZONE fb6_s, NULL::DOUBLE PRECISION fb6_sv, NULL::DOUBLE PRECISION fb6_sp, NULL::BOOLEAN fb6_pass,
NULL::TIMESTAMP WITH TIME ZONE fb7_s, NULL::DOUBLE PRECISION fb7_sv, NULL::DOUBLE PRECISION fb7_sp, NULL::BOOLEAN fb7_pass,
NULL::TIMESTAMP WITH TIME ZONE fb8_s, NULL::DOUBLE PRECISION fb8_sv, NULL::DOUBLE PRECISION fb8_sp, NULL::BOOLEAN fb8_pass
FROM vals)
UNION ALL
-- Clearwell Low Level
(WITH vals AS (
SELECT
to_timestamp(t_stamp / 1000) date_time,
(SELECT floatvalue FROM get_tag_data('filter plant/clearwell/level', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/clearwell/set points/level/low/alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/clearwell/alarms/level/low', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/clearwell/alarms/level/low test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
NULL, NULL, NULL, NULL,
date_time, sv, sp, (sv <= sp),
FROM vals)
UNION ALL
-- Clearwell Low Chlorine
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/clearwell/chlorine/value', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/clearwell/set points/chlorine/low/alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/clearwell/alarms/chlorine/low', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/clearwell/alarms/chlorine/low test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 1
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 1/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 1/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 1/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 1/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
date_time, sv, sp, (sv >= sp),
FROM vals)
UNION ALL
-- Filter Bed 2
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 2/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 2/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 2/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 2/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 3
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 3/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 3/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 3/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 3/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 4
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 4/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 4/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 4/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 4/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 5
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 5/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 5/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 5/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 5/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 6
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 6/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 6/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 6/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 6/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 7
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 7/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 7/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 7/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 7/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
UNION ALL
-- Filter Bed 8
(WITH vals AS (
SELECT
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 8/turbidity', NULL, _d.t_stamp, false, 1)) sv,
(SELECT floatvalue FROM get_tag_data('filter plant/filter bed 8/set points/high alarm', NULL, _d.t_stamp, false, 1)) sp
FROM get_tag_data('filter plant/filter bed 8/alarms/high', :start::TIMESTAMP WITH TIME ZONE, :end::TIMESTAMP WITH TIME ZONE) _d
WHERE intvalue=1 AND (SELECT intvalue FROM get_tag_data('filter plant/filter bed 8/alarms/test mode', NULL, _d.t_stamp, false, 1))=1)
SELECT
FROM vals)
) _t
ORDER BY date_time
Thank You!
