Hello!
I have a Named query in a table binded to a datetime picker value.
SELECT
AND WO.WORKORDERDATE BETWEEN :StartDate AND :EndDate
GROUP BY
WO.WORKORDERDATE,
The data time pickers has fixed values so there is something in the table when it loads.
It loads the data well but when I change the time on the datetime pickers doesn´t reload the specify Named Query.
Any idea how to make it work?
Those DateTime pickers seem to be inside flex containers. If that is so, it means that {../DateTimePicker_Start.props.value} can't be the correct path and the query should give an error.
You can start using parent.parent.getSibling.getChild.getUncle or, much better, create custom properties on the view, custom.dateTimePicker_start and custom.dateTimePicker_End.
- Bind each datepicker to the view custom property. Make the binding bidirectional.
- Edit the query binding to look at the custom properties. It will be simply
view.custom.dateTimePicker_Start, etc.
You have scrollbars on the datepicker containers. You probably need to set height : auto.
Great, thanks, now it works,
I adapt what you said, I added a custom property as bidirectional bind to the datepicker value.
I didn´t realize about the bidirectional binding at all.
The only issue is when the page loads the datepicker shows current date
instead the date by default
You have created custom.date on the datepicker. That doesn't help you. I recommend that you create it on the view.
Then, on view.custom.date create an expression binding:
now(0)
Thanks Transistor, I aplied your fix
Now I have 2 custom properties on my view so the datapicker show this values
I aplied the expression binding
Once the date format appear on the custom property I deleted the binding so I can put any date I need.
Cheers!
now(0) runs only once when the view is loaded. You can leave it there so that it gets today as start value every time.
now() <-- executes at default scan rate.
now(0) <-- executes once.
now(123) <-- executes every 123 ms.
Tip:
When showing screengrabs of the binding dialog, always show the title bar so that we can see what component the binding is on.
Thanks,
The thing is the table is part of a report tool and the StartDate should be at least one year ago
midnight(addYears(now(0), -1)) will return one year ago at 00:00:00.
