I have a barcode scanner attached to a PLC which we use to scan 3 separate barcodes for each transaction. We then have 3 separate tags in the PLC to act as a buffer to take in each barcode and then these trigger tag change scripts in ignition.
Each tag change script runs a named query which returns information on how the machine should run depending on the barcode.
we are getting errors if the barcodes are scanned quickly though, we get a transaction deadlock error with the named query(see below).
Is there a simple way to build a queue for these named queries? I was thinking about trying to use the object as part of the named query so i can start the next named query when when the previous one has started but then i end up not being able to use the tag change script to trigger the queries.
Thanks,
ava.lang.Exception: com.microsoft.sqlserver.jdbc.SQLServerException: Transaction (Process ID 110) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
