Named Query in Script, with Returned Values
Server: SQL Server 2019
In this edition, I am inserting a new record into a table using a named query and a stored procedure. The SP returns two values, the record ID and another Integer.
I would like to be able to retrieve both values and use them in the rest of the process. The record ID will be used as the user adds additional information into associated tables.
This is the code I have so far:
params = {"p_Category":category, "p_Classification":classification, "p_Description":desc, "p_ShortDesc":shortDesc, "p_Stock":stocked, "p_Review":review}
returnNQ = system.db.runNamedQuery(namedQuery, params)
self.parent.parent.getChild("flx_InputArea").getChild("TabContainer").getChild("flx_General").getChild("coord_Left").getChild("TextArea_0").props.text = returnNQ
This is what is returned from returnNQ
[{"":4021}]
When I query the table, the other value has been created, and when I test the named query, i get both values back. 103854 and 4021.
Just to show the named query results from another insert:
Thoughts?
Edit:
this is the named query:
EXEC inv.usp_Item_NewInsert :p_Category, :p_Classification, :p_Description, :p_ShortDesc, :p_Stock, :p_Review
Edit 2:
This is the SP:
CREATE PROCEDURE [inv].[usp_Item_NewInsert]
	-- Add the parameters for the stored procedure here
	@Category INT,
	@Classification INT,
	@Description VARCHAR(255),
	@ShortDesc VARCHAR(66),
	@Stocked BIT = 0,
	@Review BIT = 0
AS
BEGIN
	-- SET NOCOUNT ON added to prevent extra result sets from
	-- interfering with SELECT statements.
	DECLARE @Catalog INT
	DECLARE @ItemId INT
	SET NOCOUNT ON;
	EXEC inv.usp_GenerateCatalogNumber01 @Cat = @Catalog OUTPUT
    -- Insert statements for procedure here
	BEGIN TRANSACTION
		INSERT INTO inv.Items (CatalogNumber, [Description], CategoryID, ClassificationID, ReviewThisPart, Stocked)
		VALUES (@Catalog, @Description, @Category, @Classification, @Review, @Stocked);
	COMMIT TRANSACTION
	BEGIN
		SET @ItemId = (SELECT ItemID
		FROM inv.Items
		WHERE CatalogNumber = @Catalog)
	END
	SELECT @Catalog, @ItemId
END
GO
How is your names query constructed?
Sounds like you've got it setup as a scalar query.
Standard query type
Yeah, I should've known that from your result screenshot...
How did you determine the output of the query? Did you look at the property after the assignment? Try printing returnNQ from the script
system.perspective.print(returnNQ)
I set the text of a text area to the returnNQ variable.
in the output console I get, nothing meaningful
com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset@36275b6e
So I updated the SP to return column names for the returned values, then I used jsonEncode on returnNQ.
Now, I have this:
{"columns":[{"name":"CatalogNum","type":"java.lang.Integer"},{"name":"ItemID","type":"java.lang.Integer"}],"rows":[[103866,4033]]}
So the question is: How do I retrieve the two values, 103866 and 4033? ( I feel like I've done this once before, but I can't recall where! :frowning_face:)
Using jsonEncode or setting the named query to return JSON you should be able to use this:
returnNQ['rows'][0][0]
Not using the jsonEncode and not modifying the named query you should be able to use this:
returnNQ.getValueAt(0,'CatalogNum')
or
returnNQ = system.dataset.toPyDataSet(system.db.runNamedQuery(namedQuery,params))
system.perspective.print(returnNQ[0]['CatalogNum'])
To do this, I need to use jsonGet. And the rest of your examples work fine as well.
Thank you!
