Hi, I’ve created a named query which is a select statement from MySQL with no parameters. This is returning a null pointer exception in the Named Query but when I run this query in Workbench there’s no problem. It is a complex query returning averages & sums and takes approximately 48 seconds to run in Workbench. I also put it into a stored procedure which again runs fine in Workbench but not when I call this procedure in a Named Query it returns a Null Pointer Exception. Any help would be appreciated please
Instead of using a named query keep it as a stored procedure in MySQL and call it from Ignition
Stored Procedure Calls
Can you give us the version of Ignition that you’re using and the stack trace from the Null Pointer Exception? Thanks!
@dkhayes117 Thanks for that but it’s still a null pointer
@KathyApplebaum Below is the stack trace.
"Traceback (most recent call last):
File “event:mouseClicked”, line 2, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:497)
java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:518)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx14.f$0(<event:mouseClicked>:5)
at org.python.pycode._pyx14.call_function(<event:mouseClicked>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:761)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:187)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:278)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at com.sun.proxy.$Proxy62.mouseClicked(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.execSProcCall()
… 51 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:917)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._call(ClientDBUtilities.java:304)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:495)
… 49 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.client.gateway_interface.ResponseParser.startElement(ResponseParser.java:361)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:455)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
… 53 more
Ignition v8.0.4 (b2019091612)
Java: Azul Systems, Inc. 11.0.4
I don’t see anything really obvious in the code, so we’ll need to dig some more.
First, I’d suggest you upgrade to the latest stable version of Ignition 8 (https://inductiveautomation.com/downloads/ignition/8.0.15). There have been a lot of bug fixes since 8.0.4, so this might take care of it.
If it doesn’t, please contact support so they can help with this. (Do the upgrade first, since that’s the first thing they will have you do). As a bonus, they may be able to make some suggestions on getting that query time to something reasonable – 48 seconds is way too long.
@KathyApplebaum
Thanks for that. I will look into it and see if it makes a difference
@cmallonee Below is both the NQ config and the script on the button event. I have also included the stack trace for the button event.
File "<event:mouseClicked>", line 1, in <module>
at com.inductiveautomation.ignition.designer.db.namedquery.DesignerNamedQueryManager.execute(DesignerNamedQueryManager.java:65)
at com.inductiveautomation.ignition.designer.db.namedquery.DesignerNamedQueryManager.execute(DesignerNamedQueryManager.java:47)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities.runNamedQuery(ClientDBUtilities.java:115)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at org.python.core.PyObject.__call__(PyObject.java:497)
at org.python.core.PyObject.__call__(PyObject.java:501)
at org.python.pycode._pyx46.f$0(<event:mouseClicked>:1)
at org.python.pycode._pyx46.call_function(<event:mouseClicked>)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.NullPointerException
... 44 more
Caused by: java.lang.Exception: java.lang.NullPointerException
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor$NamedQueryInstance.execute(NamedQueryExecutor.java:414)
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.execute(NamedQueryExecutor.java:200)
at com.inductiveautomation.ignition.gateway.db.namedquery.GatewayNamedQueryManager.execute(GatewayNamedQueryManager.java:108)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.NamedQueryFunctions.executeNamedQuery(NamedQueryFunctions.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor142.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:225)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:409)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
at java.lang.Thread.run(null)
The Query Configuration is missing the part that I’m looking for. I’d like to verify that you have a database configured for the Named Query, but your screenshot omits that portion of the configuration. Please confirm that the Named Query has a database specified in the configuration. If it uses the default database for the project, please verify that the project has a database specified as part of the Project Settings.
@cmallonee Yes it does have a DB configured and not the default DB
With a database correctly specified, and no parameters taken, and a Named Query in place at Named Queries/averages, then your setup looks correct. I have encountered some users who made changes to a Named Query (like removing parameters) but then didn’t save the project before running the query who encountered similar issues. If saving the project and running the query again does not work, then you will indeed need to wait for help from support.
@cmallonee Thanks for that! I will get in contact with them.
