Named query parameter
Hi, I am using the below query. The parameter type is value(also tried using QueryString). And enclosed the value under value columns in quotes.
SELECT
[WorkCentre]--0
,[ProdOrder]--1
,[Material]--2
,[MatDescription]--3
,[DIFOTReqDlvDt]--37
,[DIFOTAckDlvDt]--38
,[DIFOTAckShipDt]--39
,[lastUpdated]--64
,[revenueTotal] ,
,[LengthExtra]--70
,[ALFExtra]
,[certificate]
,[OrderStatus]--86
,[OpenOrder]--87
,[Priority]--88
,[Complete]--89
FROM [TblExtOrders]
INNER JOIN
-- SELECT B.Section,SUM(inDateRange) AS inDateRange,SUM(within28Days) AS within28Days FROM(
-- SELECT TblExtOrders.Section ,count(TblExtOrders.Section) AS inDateRange,NULL AS within28Days FROM TblExtOrders WHERE 1=1 {whereInnerRange}
-- GROUP BY TblExtOrders.Section
-- UNION
SELECT TblExtOrders.Section,count(TblExtOrders.Section) AS within28Days FROM TblExtOrders WHERE 1=1 {whereOuterRange}
-- ) b GROUP BY b.Section
) AS B ON TblExtOrders.Section=B.Section WHERE 1=1
:whereAlloy
:whereState
:WhereFilter
:WhereProperty
But i am getting this error: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near '{'.
Can anyone suggest where am i going wrong?
When you post code, you need to wrap it within a preformatted block using either this icon image or surround your code by three back ticks (```)
E.g.:
SELECT
[WorkCentre]–0
,[ProdOrder]–1
,[Material]–2
,[MatDescription]–3
,[DIFOTReqDlvDt]–37
,[DIFOTAckDlvDt]–38
,[DIFOTAckShipDt]–39
,[lastUpdated]–64
,[revenueTotal] ,
,[LengthExtra]–70
,[ALFExtra]
,[certificate]
,[OrderStatus]–86
,[OpenOrder]–87
,[Priority]–88
,[Complete]–89
FROM [TblExtOrders]
INNER JOIN
– SELECT B.Section,SUM(inDateRange) AS inDateRange,SUM(within28Days) AS within28Days FROM(
– SELECT TblExtOrders.Section ,count(TblExtOrders.Section) AS inDateRange,NULL AS within28Days FROM TblExtOrders WHERE 1=1 {whereInnerRange}
– GROUP BY TblExtOrders.Section
– UNION
– ) b GROUP BY b.Section
Looking at your query, at face value it looks like it has a number of syntax errors. I’m not sure what all of the β€œ-0” β€œ-38” parts are for?
Or whether this part below is part of your query?
:whereAlloy
:whereState
:WhereFilter
:WhereProperty
I assume this query is inside a named query since you mention a QueryString parameter.
What are the values you’re trying for the parameter (whereOuterRange)?
These are the parts that I can see that are wrong:
Try this:
SELECT
	 [WorkCentre]
	,[ProdOrder]
	,[Material]
	,[MatDescription]
	,[DIFOTReqDlvDt]
	,[DIFOTAckDlvDt]
	,[DIFOTAckShipDt]
	,[lastUpdated]
	,[revenueTotal]
	,[LengthExtra]
	,[ALFExtra]
	,[certificate]
	,[OrderStatus]
	,[OpenOrder]
	,[Priority]
	,[Complete]
FROM
	[TblExtOrders]
		INNER JOIN
		SELECT Section, SUM(inDateRange) AS inDateRange, SUM(within28Days) AS within28Days FROM
			SELECT Section, COUNT(Section) AS inDateRange, NULL AS within28Days
			FROM TblExtOrders
			UNION
			FROM TblExtOrders
			GROUP BY Section
		) b GROUP BY Section
	) AS B ON TblExtOrders.Section = B.Section
WHERE
	1=1
	{whereAlloy}
	{whereState}
	{WhereFilter}
	{WhereProperty}
PS. You’ll need to supply all of the QueryString parameters with a value; you can’t leave these blank. If you don’t want to add an extra where clause, set these to a single space " "
