I have a Named Query that uses a global MS SQL temporary table (##temptablename)
This query runs without error in the client as part of the running project.
This query runs without error in the designer in the Testing tab of the named query.
I am attempting to run this named query in the script block of an alarm pipeline. I make the call as follows in the format discussed in the documentation for gateway scope:
dbTableName = “[default]Historian/Deviation Alarm Info/DeviationOrigin” (tag path to the parameter needed for the named query)
params = {“param1”:dbTableName}
deviationMakeupValuesDataset = system.db.runNamedQuery(“MyProject”,“namedQueryName”, params)
when an alarm is triggered, the statement produces this error in the wrapper.log
INFO | jvm 1 | 2018/12/12 14:18:28 | java.lang.Exception: java.lang.Exception: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name ‘##temptablename’.
Is there some type of issue when temp tables are used in named queries that are being run in the gateway scope?
