Named query window not working in 8.1.5
We just update Ignition form V8.1.4 to V8.1.5 yesterday.
I found a problem in this version as belows; Could you please help us to solve this problem?
1.Named query window not working (As pictured). and alarm as below when we try to reset panel.
java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.WorkspaceManager.makeNonSelectedUnavailable(WorkspaceManager.java:200)
at com.inductiveautomation.ignition.designer.WorkspaceManager.resetToDefault(WorkspaceManager.java:186)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.resetLayout(IgnitionDesigner.java:697)
at com.inductiveautomation.ignition.designer.DockableFrameMenu$1.actionPerformed(DockableFrameMenu.java:52)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.1.5 (b2021042810)
Java: Azul Systems, Inc. 11.0.10
  1. When we switch/open other project. The error is popup.
at com.inductiveautomation.ignition.designer.WorkspaceManager.clear(WorkspaceManager.java:256)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.cleanup(IgnitionDesigner.java:925)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:931)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:898)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$1.openProject(IgnitionDesigner.java:2177)
at com.inductiveautomation.ignition.designer.ProjectDialog.lambda$openProject$4(ProjectDialog.java:156)
Thank you,
We try to reinstall each module. And we found this problem occured from Sepasoft Production module V.3.81.1SP3. When I reinstall old version (3.81.2-rc2 (b2021030301) it solve this problem.
https://s3.amazonaws.com/files.sepasoft.com/mes/updates/Versions/MES/3.81/3.81.1SP3/Production-module.modl
You might also want to fix your post title. So this post won’t show up in searches when the future v8.1.15 exists. (:
