Has anyone successfully run nats.io in Ignition (as an alternative to MQTT)?
I see that their python 2.7 example on github requires the tornado package (4.2 - 6.0), which wraps asyncio. Not sure if anyone has experience trying to do this kind of stuff within the Jython constraints?
I don’t know what this is, but I already hate it, because I can’t figure out WTF it is or does from the landing page. If you hadn’t provided the MQTT clue I’d be lost
My (potentially wrong) understanding is that it’s just cloud-based pub/sub that supports a very high message throughput with a built in Prometheus/Grafana dashboard.
You’re not going to have a fun time adapting any of the Python SDKs; even if you can get them to run, they’re probably going to be catastrophically slower than they should through the Jython environment.
If you really wanted to pursue this, the ‘right’ way would be a full custom module that brings in their Java SDK. That’s a large engineering task, though.
Ignition’s built-in historian doesn’t provide a way to attach context to a record (like a batch ID). I could use the built-in historian and use table joins and timestamp comparisons, but to me that’s worse than the Java module.
Is there a best practice for storing “contextualized” timeseries data? My current best guess is: a script that reads the tags, gets the context, and sends an MQTT message to a custom store.
Thanks @lrose – I’ve taken this approach before. And it definitely works.
But currently I need to connect multiple factories to the same cloud-based data store. So my thinking is that if I put everything in a site-specific databases, I’ve just punted my problem further down the road. And if it’s a global database, I’m likely to exceed the write limits.
Have a small update in this for any future readers. Nats.io supports MQTT, so the best thing might be to point the MQTT client towards a Nats.io server with MQTT enabled.
Been a few years since this post but wanted to mention that we tired to use MQTT NATS bridge as a solution but we have a very large throughput of data and were seeing issues with processing the stream over MQTT (latency issues), along with NATS labeling the client as a slow consumer terminating the connection so I started to switch over to use their native java library, first time doing any type of module dev so still working out a few bugs however results look promising so far!
My module uses a ManagedTagProvider to write new values to a tag based on the subject path as new messages are consumed. If you start having issues with the MQTT implementation might be good idea to look at the java client library instead of python 2.7
