Wondering if there is a way to use a table for navigation? I would like for a user to be able to double click a row in a table and pass a parameter from a column in selected row to another window and open that window. Any suggestions would be great.
Some assumptions, but in a “mouseClicked” event script on the table:if event.clickCount==2:
table = event.source
if table.selectedRow>=0:
param = table.data.getValueAt(table.selectedRow, "columnName")
system.nav.openWindow("windowName", {"paramName": param})You should check the docs for system.nav.openWindow() and Parameterized Windows.
Worked perfectly! Thanks again pturmel!
