Hello team,
Im trying to navigate to another view after onAuthChallengeCompleted event script to but its not working for me.
Anyone can help me on that?
First thing's first - learn to post code snippets.
Secondly, onAuthChallengeCompleted event runs in the gateway scope but you're trying to access it via a function in the session scope. You'd need to implement the session ID in your script.
Hi @Fran_Dujmovic,
Thanks for suggestion, I have tried to implement session Id but I'm getting error:
Channel is not set.
I have attached code:
def onAuthChallengeCompleted(session, payload, result):
if result.isSuccess():
# Parse information about the successful result
success = True
context = result.getAsSuccess().getContext()
user = context.user
roles = user.roles
AllSession= system.perspective.getSessionInfo()
for user_session in AllSession:
if user_session.id==session.props.id:
page_ids=user_session.pageIds
for page_id in page_ids:
logger = system.util.getLogger("Authentication Challenge-Roles")
logger.info("%s is session_id"% user_session.id)
logger = system.util.getLogger("Authentication Challenge-Pageid")
logger.info("%s is page_id"% page_id)
system.perspective.navigate(view='User Management/RoleConfiguration',sessionId=user_session.id,pageId=page_id)
Please help me to implement session id?
First, we can start by changing
to just use the session parameter that's already provided for you in the function.
Are you actually trying to redirect every tab a person may have open to the User Management/RoleConfiguration view after a successful authentication? Seems a little bit odd, but this could be a customer requirement.
Here is a very helpful docs page that goes into this a little bit.
Hello @YF129701 ,
Yes, after successes full authentication user will navigate to respective screen. But currently im unable to navigate due to facing error
Can you post a screenshot of the error you're facing?
