I used this function system.util.retarget but, throwing some errors.
I need solutiion for this one. so, if you know the answer, pls reply.
Thanks.
Try system.util.retarget.
This error throwing that function. system.utill.retarget
That's what you said in your first post.
You have a spelling mistake. It is util, not utill.
https://docs.inductiveautomation.com/display/DOC81/system.util.retarget
Can you just post the actual code you're using? All of it, ideally.
Is there a log that would record the stack trace for that exception? I'm not sure if it would be the Vision client launcher log or some client-specific log.
