I have a table on a screen title ‘Production Standard by Customer’ At the bottom of that screen I have an edit button and an add button. Both of these buttons with bring up a popup type of screen where the user can either add a new record or edit the current record.
Currently the way in which I am doing thing is when I select a record from the table I will press the button for edit and it will open the popup menu and fill the proper values into their respective cell. Once I have updated the record I will press the submit button and it will write the data to the table. Then I have a DB tag in SQL tags that I write to when closing the popup screen. On the ‘Production Standards by Customer’ Screen I watch this tag. When the tag goes to a 1 (one) I preform a db.reFresh on the table and then reset the tag to a 0 (zero).
I am wondering, is this the best and most efficient way to accomplish this? Currently the table is set to polling off.
