Navigation in React component
I'm making a third party module which uses React components to make a new Navigation menu. Currently I'm using this code to change to a new page:
onLinkClick(pageName: string) {
    //@ts-ignore
    this.props.store.clientStore.mounts.navigateTo(pageName);
This works, but it seems looks like a hack. In addition the session variable page.props.title is not updated nor the url in the browser.
Are there any better ways of doing it?
That's the way I'd do it :man_shrugging:
That seems to be what we're doing in the navigation action:
                } else if (config.page) {
                    if (config.newTab) {
                        const client: ClientStore = component.view.page.parent;
                        const url = `${client.getBasename()}${config.page}`;
                        window.open(url, "_blank");
                    } else {
                        client.history.push(config.page);
                } else if (config.view) {
                    client.mounts.navigateTo(config.view, config.params);
                } else if (config.url) {
                        window.open(config.url, "_blank");
                    } else {
                        window.location.href = config.url;
It is apparently intentional that this doesn't change the title/URL:
     * Can by called by other parts of the API to navigate to a view with a given set of params. Navigating in this way
     * will change the primary view without changing the url path.
Hi Torstein,
It looks like you're on the right track with your approach to handling navigation in your module. As Bmusson mentioned, it seems to be a common practice. However, if you're looking to update the session variable page.props.title and the browser URL, you might want to consider utilizing the history object from React Router.
