RedViking is pleased to introduce the Redviking Navithor Interface; a module that bridges the gap between Ignition and Navithor's AGV/AMR fleet manager service.
Get connected to Navithor and start controlling AGV/AMRs within minutes thanks to the modules minimal start up configuration and built in drag and drop views.
Features
- Real time data reporting on AGV and production area status
- Intuitive, well documented API that is both versatile and finely detailed, capable of accommodating nearly any use case
- Full functionality in trial mode (only while the trial is active)
- No required tags or connection to external devices. All data is stored within the module and accessed via API to keep complexity low
- Minimum additional load to the gateway (did not see any increase to gateway resource consumption after initial install on in house production servers)
- Multiple prebuilt components that provide quick solutions for deployment, testing, and debugging
Compatible Ignition Versions
- 8.1
Resources
- API Documentation/ MODL download
- Navithor Fleet Control
- Ignition Module Showcase
- RedViking Home Page
This module is created and maintained by RedViking, who actively designs, builds and deploys AGVs and AMRs.
