Hello all,
I’m facing an issue with controlling the legend in the XY Chart component in Ignition Perspective. The default legend allows me to show/hide bars properly. However, when I try to control the visibility using the visible property, it only hides the series but leaves an empty space instead of disabling it like the default legend does.
Additionally, when I click on the default legend to hide a series, the change is not reflected in the visible property. I need a way to programmatically control this behavior while ensuring the legend and series visibility stay in sync.
Has anyone found a solution for this?
Thanks in advance
