I am collecting estop data to record how many times estops are being pressed in a month. The issue I have ran into is that because the data is logged when the tag value goes low it captures the line being locked out as a total estop. This is skewing my results:
The Query I am running:
SELECT EstopActivity.Department, EstopActivity.LineNumber, EstopActivity.EStop, EstopActivity.[TimeStamp] FROM EstopActivity WHERE Department= 'Primary Extrusion'
Is there something I can add to this query in order to only pull estop data with a “unique” Timestamp?
