Need help keeping column amount Fixed with import using csv reader
I am using this script mishmashed from posts on this forum/IA's csv info page , and it almost works the way I need it too , but I need help with how its imported
	##importing from 2 libraries
	from StringIO import StringIO
	import csv
	grabbedfile =  event.file.getString("UTF-8")
	Headers = ["Feature","X","Y","Z","i","j","k","DIA"]
	#this is the empty list
	CsvData = []
	#this is the grabbed file stored in strings in lists , per row
	StringLists =  [row for row in csv.reader(StringIO(grabbedfile))]
	for inner_list in StringLists:
	    for element in inner_list:
	    	#put it in the empty list
	        CsvData.append(element)
	#this prints the list as a whole
	#system.perspective.print(CsvData)
	#split into groups of 8
	ListGroups = zip(*(iter(CsvData),) * 8)
	#system.perspective.print(ListGroups)
	tagpath = "CSVData"       ##tag I am putting the data in
	ds = system.dataset.toDataSet(Headers,ListGroups)
	system.tag.writeBlocking(tagpath,ds)## this line is shoving all the data into the above tag
	FileNametagpath = "FileName"       ##tag I am putting the data in
	FileName = event.file.name
	system.tag.writeBlocking(FileNametagpath,FileName)
the problem I am having is that the CSVs I am importing from a machine are in a weird format
the columns will look like
Name,1,2,3,4,5,6,(Blank)
Name,1,2,3,4,5,6,7
Name,1,2,3,4,5,6,7
because the 8th column doesnt have any values in it until later on , everytime I import it offsets all of the values from the next rows and starts making a mess out of the system going on afterwards
I have been getting around this by just entering any value into the first row and the 8th column in the csv before I import it , but it would be nicer if I could just drag and drop the CSVs without having to do this everytime. Is there anyway to make it act like there is 8 columns even if the first row only has 7 values?
Can you give a sample file?
nvm. Try:
StringLists = [(row+([None]*8))[:8] for row in csv.reader(StringIO(grabbedfile))]
This should force all rows to 8 elements
