Hello,
I have an object that can rotate around a fixed center position.
No problem to display that but the problem is that the object can also move further away from the center position. When I then rotate the object it rotates around its own center but it schould rotate around the fixed center position.
So I have the angle of the object and the distance from the center.
Attached are some examples of possible positions.
Any idea if and how I can do that in Ignition?
Rotation.pdf (2.98 KB)
