Need to align the column and row size in Perspective table
I trying to align the column heading to align to row correctly, also need to know how to give the spacing between column?
kindly help me with simple issue
I trying to align the column heading to align to row correctly, ...
The best thing to do here is to replace the _ characters with spaces.
  • Easy way: Type them into columns.x.header.title for each column x.
  • Script way: read the headers, replace '_' with ' ' and script the columns.x.header.title.
... also need to know how to give the spacing between column?
Create a style class, paddingLR (left-right). Set
padding-left : 5px
padding-right : 5px
On each column select the paddingLR from the header styles dropdown.
columns.x.header.style.classes : paddingLR
thank you. Will check it
Thank you for your valuable input. Actually I tired the same as you instruted. But none is changing . Kindly check.
For your info, table data is coming from a tag. Not able to resize the columns also even though I have enabled the resizable - True.
You need to fill the field property of each column. Without that the column configurations don't apply
Isn't there a "global" column style property ?
Yes, column.x.field must be defined.
I never found a global columns property and always set each column individually.
Sure thanks . I found the thing. Thank you
