Hi everyone.
I have a table on a DB I need to traspose on an Ignition Table, but I need to filter it by just selecting the rows where the value of the "FullPlantName" column match the "SelectedPlant" session property.
Is there a way to make queries and session property interact somehow? Or is there any way I could work around it?
- In Project Properties set the default database to whichever one you want.
- Create a new Named Query (at the bottom of the Project Browser tree).
- Add a
SelectedPlant parameter of appropriate type to the named query. Use this in your query using syntax :SelectedPlant.
The query should look something like,
SELECT *
FROM myDataBase
WHERE FullPlantName = :SelectedPlant
ORDER BY <name of field>
- Create a binding on the table's
PROPS.data. Select Query binding, select the named query and point the parameter at your session property.
Hi! sorry for my late answer. it Worked!! Thank you!
