Hello,
I've got a reporting module issue. I've got a client with a production testing policy that has inconsistent start and end times. Is there a way to have the report generator run on a trigger rather than at a specific time every day?
I've got all the data I need as OPC tags including the flag that signals the start or end of a test. If I can get it to just look at an item and run after that value turns to a 1 then that would be perfect, but the scheduling tab of the report builder seems to only work off of timestamps.
If it's impossible then I could just pull the needed data into a table, and have an event script export it as an excel file whenever I need. However I'd prefer to keep the more flexible formatting of exporting as a PDF.
Any help would be appreciated. Thanks.
