Hi all.,
I have page, that need to add machine details. machine details are recorded in DB. I need to configure the embeeded view based on one condition,
Condition 1: if table has data it should respective table data in table component[That has separate view]
Condition 2: if table is empty, it should another view as called "No data to show"
Attached the picture that should show in embedded view when table is empty!
kindly help!
- Create a view. I will assume you are using a flex view.
- Add a Table component.
- Set
POSITION.grow : 1. - Create a binding on
PROPS.datato get the information to be displayed. - Add a Label component.
- Set
POSITION.grow : 1. - Set
PROPS.text : No data to show.
Create a binding on the Table's POSITION:display.
Figure 1. Table.
Create a similar binding on the Label's POSITION.display but set the expression to as follows:
Figure 2. Label.
Now the table should display if there is data. The label should display if there is no data.
Thank you for your reply. I will try now!
There was an error in my Figure 2. I fixed it.
Be careful with your comparison ....value} > '0'. You are comparing a query tag result (dataset or JSON) with a string '0'. This might not work in the way you expect in all cases.
If you are looking for a non-empty string then it should be ....value} > '' but whether either solution is correct depends on the data type / structure.
Thank you.Noted
