Nested Query Tag Historian Report - Returning First Row
I'm working on building a report to export tag history values for a given time frame. When I run the report, only the first line shows up, however, if I look at the preview, I can see the timestamps and history. What am I doing wrong? I want it to display all the values for that timeframe.
Show your table's configuration, in the Design tab. Only getting the first row almost always means that the table isn't set up properly.
You will need a table group to handle your nesting. You are legitimately getting one row at the CTBs level.
You're absolutely right, I missed that.
Thank you, I'm getting all of my rows now!!!
Perfect! Thanks again.
You were correct, thanks for the quick response.
