Nested UDT: bind sub UDT parameter to a parent UDT tag
i would like to know if there is a way to bind a nested UDT parameter to a parent UDT tag. I know that you can "bind" it to a parent UDT parameter.
You can't bind UDT parameters to anything but other UDT parameters and perhaps some other special keywords (can't remember).
However, you can use a tag change script to modify the UDT parameter value on change of the tag value.
