Nested UDT parameter passing BUG
Hello, i have found a bug where parameter passing other parameters in the base datatype results in null/issues but when the same parameter is passed in manually it works
Broken step 1) - structure layout
Broken step 2) - pre-filled out parameters
Broken step 3) - blank UDT instance created
Broken step 4) - blank UDT parameters filled in
Broken step 5) -expanding alarm parameters shows null/bad values
Working step 1) -deleted prefilled parameter values
Working step 2) -Same as broken step 3/4
Working step 3) - Filling out parameters manually on the instance versus the definition
Working step 4) Green light confirms overwridden
Working step 5) Overwritten variables worked
General picture - parameters im sending into the alarm UDTs are found on the base UDT object
Semi-working step 1) - In the new instance creation window, if i prefill the parameters versus after i make the tag
Semi-working step 2) - The values fill out properly however the alarm message doesnt link right
Semi-working step 3) - The Label is the ALARM_MESSAGE and is basically treated as null which is why Alarm is displayed (name of the alarm)
Semi-working step 4) - This is the alarms configuration
General - At the moment, it appears the only way to get it working properly is to make a blank UDT and fill in the parameters after creation, because the semi-working only gets the address and PLC part right, but the alarm message for some reason returns null, but its not ideal due to manual work versus the parameters being properly passed through
also here are my ignition versions
We’ve addressed a number of issues related to UDT Parameters recently. Upgrading to 8.0.15 should fix what you were seeing.
