Nested UDT Parameter Passing Issue
Currently Installed 8.0.13-rc1 (b2020051415)
Nested UDT’s within a primary UDT are failing to pass the parameters in if a modifier is used to the downstream tags. The below image is what parameters get passed in. I add the “.Interlock” to be added to the Nested UDT. This parameter is being passed into the Nested UDT but not to the Nested UDT tags.
2020-05-26_15-30-31-187
Thanks for any support on the matter.
Regards,
Was on phone with IA for this same issue today. It was a regression from 8.0.12. The fix is supposed to be ready for 8.0.13 release.
