Nested UDT parameters override
Hi everyone,
I am working with nested UDT and I have a lot of UDTs which implement another UDT instaces. I some cases, I have to override the nested UDT’s parameters. Then, since the UDT editor does not have an overriden indicator as the tag editor has, I find the next drawbacks:
  • You do not know when a nasted UDT’s parameter is overriden or not.
  • If you want to remove a parameter’s override you can’t do it. The only way is to edit the json removing the parameter asignment in the nested UDT instance or to delete and reinstanciate the nested UDT.
  • Since you do not know when a nested UDT’s parameter is overriden, when you change a parameter value in the UDT definition there is no way of knowing if it will affect the nested UDTs, depending on whether their parameters are overriden.
I have built a json example to support the explanation, with two very simple UDT definitions called “UDTA” and “UDTB”.
In this case, the “UDTA” has two parameters (“ParameterA” and “ParameterB”). The “UDTB” has two instances of “UDTA” called “UDTA_1” and “UDTA_2”. Parameters in “UDTA_2” will take their values 100 and 1000 respectively from the “UDTA” definition while “UDTA_1” only will take “ParameterB” value from the definition since “ParameterA” has assigned with the value 50 in its declaration which overrides the value.
  "name": "NESTED_UDT",
  "tagType": "Folder",
  "tags": [
      "name": "UDTA",
      "parameters": {
        "ParameterB": {
          "dataType": "Integer",
          "value": 1000
        "ParameterA": {
          "value": 100
      "tagType": "UdtType"
      "name": "UDTB",
      "tagType": "UdtType",
      "tags": [
          "name": "UDTA_1",
          "typeId": "NESTED_UDT/UDTA",
          "parameters": {
            "ParameterA": {
              "value": 50
          "tagType": "UdtInstance"
          "name": "UDTA_2",
It may be improved by IA in the designer or there is something I am overlooking?
Take a look at the latest version of 8.1.17 released yesterday. This is one of the issues that was addressed as part of the Tag Editor revamp:
In versions prior to 8.1.17, using the trash can icon to ‘delete’ the Parameter would revert the override, but it wasn’t very intuitive. Hopefully the changes make it easier to resolve the issues you are seeing.
Garth
Hi @ggross
Thanks for your response.
I’ve finally tested the new version and, as you said, this problem is solved. It actually implements the green indicator I asked for within each parameter of the nested UDT instance.
So now the user can know when the parameter is overriden and can even remove the override by clicking on it.
Thank you for your useful comments.
Manuel
This is small but brilliant :slight_smile: Thanks @ggross and team. It’s the creature comforts that make software enjoyable to use, and this is certainly one of them
