Neumeric text field does not write value into plc via popup window via indirect addressing
i have rockwell controllogix plc while writing data into analog addon via popups it will not happen, but if i write value in tag directly in main windows it will sucessfully write value into tag in analog addon
@rrajatrcs Can you write anything from said popup?
Is your component binding for the text field set to be bidirectional?
yes
