I keep getting this error whenever I try to create a new database connection. Has anyone ever ran into this before? I can still go into the Ignition Internal DB and insert the connection that way, but it’s very tedious and time consuming.
v7.9.16
This looks like a bug I thought we had fixed, but I can’t readily find the details. Can you check the gateway logs to get the additional details of the error? I suspect that the problem is with the autoincrement sequence on the Datasources table of the internal DB.
