New Edge 7.9.13 install on Ubuntu 18.04 not allowing us to create roles
We are trying to set up ignition edge 7.9.13 for a project we want to deploy we have ordered a license but it’s not here yet. When trying to add roles to any authentication profile including the default one the server crashes with an internal error and doesn’t recover I need to restart the service for it to come back.
OS: Ubuntu 18.04
Java Version: 8
Ignition version: 7.9.13
INFO | jvm 1 | 2020/03/26 19:40:52 | Caused by: java.sql.SQLException: Connection is locked. Datasource only allows one connection at a time. More information was logged to the gateway console.
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.localdb.sqlite.SingleConnectionDatasource.getConnection(SingleConnectionDatasource.java:75)
INFO | jvm 1 | 2020/03/26 19:40:52 | at simpleorm.sessionjdbc.SSessionJdbc.innerOpen(SSessionJdbc.java:111)
INFO | jvm 1 | 2020/03/26 19:40:52 | … 53 common frames omitted
INFO | jvm 1 | 2020/03/26 19:40:52 | W [g.LicenseManager ] [19:40:51]: Unable to update demo time remaining.
INFO | jvm 1 | 2020/03/26 19:40:52 | simpleorm.utils.SException$Jdbc: Opening com.inductiveautomation.ignition.gateway.localdb.sqlite.SingleConnectionDatasource@6951d08f
INFO | jvm 1 | 2020/03/26 19:40:52 | at simpleorm.sessionjdbc.SSessionJdbc.innerOpen(SSessionJdbc.java:113)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.localdb.persistence.PersistenceSession.initialize(PersistenceSession.java:31)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:62)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.save(PersistenceInterfaceImpl.java:100)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.modules.LicenseManagerImpl.saveTrialTimeRemaining(LicenseManagerImpl.java:863)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.modules.LicenseManagerImpl.shutdown(LicenseManagerImpl.java:203)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.shutdown(ModuleManagerImpl.java:1135)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.SRContext.shutdownInternal(SRContext.java:1752)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.SRContext.shutdown(SRContext.java:2426)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.SRContext.onDestroy(SRContext.java:2414)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.apache.wicket.Application.internalDestroy(Application.java:665)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.apache.wicket.protocol.http.WebApplication.internalDestroy(WebApplication.java:613)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.apache.wicket.protocol.http.WicketFilter.destroy(WicketFilter.java:528)
INFO | jvm 1 | 2020/03/26 19:40:52 | at com.inductiveautomation.ignition.gateway.bootstrap.SRFilter.destroy(SRFilter.java:85)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.servlet.FilterHolder.destroyInstance(FilterHolder.java:172)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.servlet.FilterHolder.doStop(FilterHolder.java:150)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:89)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:143)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:161)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.server.handler.AbstractHandler.doStop(AbstractHandler.java:73)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.servlet.ServletHandler.doStop(ServletHandler.java:226)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.security.SecurityHandler.doStop(SecurityHandler.java:381)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.security.ConstraintSecurityHandler.doStop(ConstraintSecurityHandler.java:456)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.server.session.SessionHandler.doStop(SessionHandler.java:127)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.server.handler.ContextHandler.stopContext(ContextHandler.java:819)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.servlet.ServletContextHandler.stopContext(ServletContextHandler.java:355)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.webapp.WebAppContext.stopWebapp(WebAppContext.java:1385)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.webapp.WebAppContext.stopContext(WebAppContext.java:1349)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.server.handler.ContextHandler.doStop(ContextHandler.java:874)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.servlet.ServletContextHandler.doStop(ServletContextHandler.java:271)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.webapp.WebAppContext.doStop(WebAppContext.java:541)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.server.Server.doStop(Server.java:476)
INFO | jvm 1 | 2020/03/26 19:40:52 | at org.eclipse.jetty.util.thread.ShutdownThread.run(ShutdownThread.java:138)
INFO | jvm 1 | 2020/03/26 19:40:52 | I [g.ModuleManager ] [19:40:51]: ModuleManager shut down in 37290ms
INFO | jvm 1 | 2020/03/26 19:40:52 | I [c.i.i.g.g.WSChannelManager ] [19:40:51]: Shutting down GAN channel manager.
INFO | jvm 1 | 2020/03/26 19:40:52 | W [SRContext ] [19:40:51]: Trying to remove servlet “ws-control-servlet”, but map servlet is gone.
INFO | jvm 1 | 2020/03/26 19:40:52 | W [SRContext ] [19:40:51]: Trying to remove servlet “ws-datachannel-servlet”, but map servlet is gone.
INFO | jvm 1 | 2020/03/26 19:40:52 | W [SRContext ] [19:40:51]: Trying to remove servlet “http-datachannel-servlet”, but map servlet is gone.
INFO | jvm 1 | 2020/03/26 19:40:52 | W [SRContext ] [19:40:51]: Trying to remove servlet “http-ping-servlet”, but map servlet is gone.
INFO | jvm 1 | 2020/03/26 19:40:52 | I [Tags ] [19:40:51]: Shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [C.BasicExecutionEngine ] [19:40:51]: Execution engine ‘gateway-tagprovider-edge-sc’ shut down in 0ms
INFO | jvm 1 | 2020/03/26 19:40:52 | I [T.Provider ] [19:40:51]: Tag provider ‘edge’ stopped. tag-provider=edge
INFO | jvm 1 | 2020/03/26 19:40:52 | I [G.OPCManager ] [19:40:51]: OPCManager is shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [G.OPCManager ] [19:40:51]: Shutting down OPC server connection: “Ignition OPC-UA Server”
INFO | jvm 1 | 2020/03/26 19:40:52 | I [G.OPCManager ] [19:40:51]: OPCManager shut down in 0ms
INFO | jvm 1 | 2020/03/26 19:40:52 | I [SessionManager ] [19:40:51]: Shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [ProjectManager ] [19:40:51]: ProjectManager shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [A.N.NotificationManager ] [19:40:51]: Shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [A.S.StorageManager ] [19:40:51]: Shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | I [i.UserSourceManager ] [19:40:51]: Shutting down…
INFO | jvm 1 | 2020/03/26 19:40:52 | E [c.i.i.g.l.s.SingleConnectionDatasource] [19:40:51]: The following stack successfully received a connection. A new attempt was blocked for over 30000 ms
INFO | jvm 1 | 2020/03/26 19:40:52 | java.lang.Throwable: null
Same issue as here, I think: Ignition Edge: Adding new users/roles gateway locks up
Unfortunately it sounds like rolling back to 7.9.12 until 7.9.14 is released is the only option.
Thank you I did not see that post ill just use 7.9.12 for now and idea when 7.9.14 will be released?
7.9 releases are spaced fairly far apart these days, looks like it’s currently scheduled for April 28 :pensive:
Ok no worries i ended up installing 7.9.12 making all the changes to the roles i needed then upgraded to 7.9.13 and working good for now
