I recently merged a Vision project with a Perspective project so they can share scripting modules. Now as of tihs morning after making this push, oddly enough the navigation in my Vision project is acting buggy - sometimes the window does open at all ie I get blank grey screen like this
but it doens’t always happen.
Here’s the full error
File "<event:actionPerformed>", line 16, in swapWindow
at java.base/java.util.Timer.sched(Unknown Source)
at java.base/java.util.Timer.schedule(Unknown Source)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.startTask(AbstractPollingFunction.java:65)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.startup(AbstractPollingFunction.java:52)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.startup(FunctionExpression.java:63)
at com.inductiveautomation.ignition.common.expressions.AbstractExpression.startup(AbstractExpression.java:61)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.startup(FunctionExpression.java:62)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:110)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupBindings(DefaultInteractionController.java:355)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:344)
at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:554)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:197)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$openWindowImpl$5(NavUtilities.java:393)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:815)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:336)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:326)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
java.lang.IllegalStateException: java.lang.IllegalStateException: Timer already cancelled.
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:518)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx116.swapWindow$1(<event:actionPerformed>:16)
at org.python.pycode._pyx116.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:456)
at org.python.core.PyFunction.__call__(PyFunction.java:451)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:788)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientSystemUtilities.lambda$invokeLater$1(ClientSystemUtilities.java:276)
Caused by: java.lang.IllegalStateException: Timer already cancelled.
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
... 26 more
Ignition v8.0.6 (b2019111216)
Java: Azul Systems, Inc. 11.0.4
and here’s the logic on the navigation buttons that never caused an issue before
def swapWindow(event = event):
import system
for window in system.gui.getOpenedWindows():
print window.getPath()
if window.getPath() == '_Header':
print 'Header found'
elif window.getPath() == '_navLeft':
print 'Found navLeft'
else:
system.nav.closeWindow(window.getPath())
system.nav.openWindow(event.source.outWindowName)
system.tag.write("[Client]PopupLoading", 1)
system.util.invokeLater(swapWindow)
Any idea whats going on?
