We are proud to announce two new formulae!
Prerequisites
- macOS Mojave, Catalina, or Big Sur
- Homebrew
How do I install these formulae?
To install these formulae, first tap our Homebrew tap
$ brew tap coatl-dev/coatl-dev
And then, for ignition-edge@8.1.2:
$ brew install ignition-edge@8.1.2
Or for ignition@8.1.2:
$ brew install ignition@8.1.2
Or with one single command.
For ignition-edge@8.1.2:
$ brew install coatl-dev/coatl-dev/ignition-edge@8.1.2
$ brew install coatl-dev/coatl-dev/ignition@8.1.2
How do I start the Ignition Gateway?
Please make sure you don't have another Ignition Gateway running on port
8088. If you do, please stop it by runningignition@X.X.X stoporignition-edge@X.X.X stopif you've installed from our Tap, orignition stopif you've installed it directly from Inductive Automation.
Once installed, open a new Terminal window and run the following command:
$ ignition-edge@8.1.2 start
Or
$ ignition@8.1.2 start
Once the Service starts, you can go to http://localhost:8088/ to provision your Gateway.
How do I start Ignition automatically at login?
Run the following command:
$ brew services start coatl-dev/coatl-dev/ignition-edge@8.1.2
Or
$ brew services start coatl-dev/coatl-dev/ignition@8.1.2
Discussions
If you run into any issue, feel free to post something at our Discussions.
