Hello Forum,
is it possible to create a tag which will run a python script and calculate differences from other tags?
what kind of display do i have to use? (label , numeric label etc) in order to see the data from the script.
do i have to create the tag on the ignition designer or on the gateway?
You can then use this tag with a numeric display to visualize it for an operator, or just see the value in the Tag Browser if that’s all you need to do.
i created the expression tag as value source expression and data type float but in the expression can i write python?
when i write anything as a script inside i see a red X which indicates a bad tag.
The expression language addressed by @BryanB and @JordanCClark is great for simple calculations but if your calculation is more complex, you will want want a tag event script.
You can write a python script that will execute whenever the value of one the tags of interest changes.
Write the result of the calculation into a third tag that is displayed to the user.
