I’m trying to run mvn package on an Ignition module that I’ve recently copied from another computer. The module is originally cloned from the OPC device example on github: ignition-sdk-examples/opc-ua-device at master · inductiveautomation/ignition-sdk-examples · GitHub, and uses a pretty much identical pom.xml. Packaging this module has worked in the past (this is the first time I’ve tried to package it in about 2 months).
The command gets stuck on this line:
Downloading from releases: https://nexus.inductiveautomation.com/repository/inductiveautomation-releases/org/apache/maven/plugins/maven-install-plugin/2.4/maven-install-plugin-2.4.pom
And following that URL, gives me a 404 page, so I’m assuming that is why the mvn package command doesn’t continue.
Is there something wrong with the Nexus repository? Should I change the url?
Thanks in advance
Hi there.
I’ve seen this too but not sure what I did because I have seen it but once. I’m new at building modules and and packaging and am not sure if I can help but I’ll try. My build pom starts like this:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
There aren’t any worthy search results when I search for instances of maven in my project. I searched on Nexus and found only this:
28: <url>https://nexus.inductiveautomation.com/repository/inductiveautomation-releases</url>
42: <url>https://nexus.inductiveautomation.com/repository/inductiveautomation-releases</url>
54: <url>https://nexus.inductiveautomation.com/repository/inductiveautomation-snapshots</url>
66: <url>https://nexus.inductiveautomation.com/repository/inductiveautomation-thirdparty</url>
I’ve been using the pom files from the example vision-component I cloned from GitHub…it works just fine…even after I modified it
Good luck!
T.
