We are trying to configure an nginx reverse proxy.
Even though connecting to our 7.9 server works just fine, trying to connect to our 8.1 server times out after pressing the login in button.
Watching the requests sent to the server, we’ve noticed that a GET request is sent to http://10.10.10.11/idp[...] instead of http:/10.10.10.11:8100/idp[…] which understandably times out as there is nobody listening on the 80 port. What’s even wierder is that this request is sent to the correct port when talking to the igniton 8.1 server directly.
Our servers being located at:
Ignition 7.9 → 10.10.10.10:8088
Ignition 8.1 → 10.10.10.11:8100
Our nginx config file being:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
http {
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
include /etc/nginx/mime.types;
default_type application/octet-stream;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
gzip on;
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
server {
# Ignition 7.9 server
listen 8088;
location /main/system/mobile {
valid_referers blocked server_names ~.*project=(?:proj1|proj2).*;
set $REQ_CAN_PASS "false";
if ( $arg_project ~ ^(?:proj1|proj2)$ ) {
set $REQ_CAN_PASS "true";
if ( $invalid_referer = '' ) {
if ( $REQ_CAN_PASS = "false" ) {
return 404;
resolver 1.1.1.1;
proxy_pass http://10.10.10.10:8088;
location / {
return 404;
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream perspective {
server 10.10.10.11:8100;
server {
# Ignition 8.1 server
listen 8100;
location / {
if ( $uri ~ /data/perspective/(?:client|project|login)/(?:proj1|proj2) ) {
if ( $uri ~ /res/perspective/.* ) {
if ( $uri ~ /data/perspective/(?:themes|style-classes|fonts|hello|translation|keepalive).* ) {
if ( $uri ~ /idp/.* ) {
if ( $http_upgrade = "websocket" ) {
return 404;
proxy_pass http://perspective;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
