Hi, just to see whether the following setup will work on ignition backend calling webdev API:
- use NGINX as reverse proxy server.
- setup multiple ignition gateway server on different clouds.
- develop ignition web dev for API comms with client.
- use NGINX to distribute the load.
This setup works pretty well on NGINX & node.js, but will it work for ignition?
And if I already have two ignition gateway set up as redundant server, do I need to remove the redundancy to get the load balancing function working? Assuming both gateway have the same setup of web dev APIs.
