Hi, I started a project using Kepware but am now trying to use National Instruments OPC server instead. It looks to me to be Kepware KEPserverEX5 replicated bar the title and port. When trying to setup the OPC UA connection states faulted. In the NI OPC admin it has a connection request from ignition which I have set to trusted. So it appears to me that it is trying to connect, I am not sure why it is faulting out.
Edit to add version 7.7.5 on windows 7 32bit. I also checked the console and found this:
I'm currently using 2.6/4GB
I will try deploying on a 64 bit machine with more RAM.
