Nightly 8.1 Changelogs - 2023
Weekly Changelog: 8.1.26-b20230303
Security
7255: XPath expressions which select all nodes of an element by name fail after upgrade to 8.1.25
Fixed a SAML XPath regression which could cause a NPE for expression attribute mappers and security level rules.
Tags
7047: UDT Parameters do not handle Locales properly
UDT Parameters will correctly handle different Gateway locales
Swing
7279: Named Query "Cache Query Results" checkbox is enabled for Update Query type in Designer
Fixed a problem introduced with IGN-183 for NamedQuery readonly mode. Controls that provided input (textfield, eg) were not correctly enabled/disabled in non-readonly mode.
Infrastructure
7109: Upgrade bundled JRE to 11.0.18
Upgraded bundled JRE to 11.0.18
