Nightly 8.1 Changelogs - 2026 and beyond
Nightly Changelog: 8.1.55-SNAPSHOT-b20260723
Perspective
Perspective
IGN-16877: 8.1 backport: OPC-HDA tags are not being listed in Power Chart (IGN-9689)
Fixed an issue where OPC-HDA tags were not visible in the Perspective Tag Browser / Power Chart.
Nightly Changelog: 8.1.56-SNAPSHOT-b20260831
Comms
OPC
IGN-16682: ConcurrentModificationException in OPC UA subscription node handling (8.1 fix)
Fixed a rare issue where an OPC connection starting or reconnecting while tags were being added or removed could log a ConcurrentModificationException and fail to subscribe to some tags.
Nightly Changelog: 8.1.56-SNAPSHOT-b20260917
Alarming
Twilio
IGN-17765: Back Port: Upgrade Twilio Java Helper Library to 13.0.0+
Updated the Twilio Notification Module to version 13.0.0 of the Twilio Java Helper Library.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261006
Perspective
Perspective
IGN-9851: onDrag position of cursor is out of sync with Popup
Fixed an issue with cursor lag when dragging popups.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261013
Infrastructure
Java - Azul
IGN-18000: Bump to CSPU release 17.0.20.1 in 8.1
The bundled version of java was upgraded to 17.0.20.1 to address security vulnerabilities
Nightly Changelog: 8.1.56-SNAPSHOT-b20261026
Perspective
Perspective
IGN-18155: Backport: Translations: ‘Ignore Whitespace’ setting only strips out whitespace if more than one whitespace character in sequence
Fixed an issue where the Ignore Whitespace translation setting did not match terms containing a single whitespace character in Perspective, causing those terms to remain untranslated.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261028
Perspective
Workstation
IGN-18266: Backport: Workstation Requires Authentication on Primary and Secondary Displays when IdP settings are enabled in Designer Project Properties
Fixed an issue where Perspective Workstation prompted users to authenticate on both the Primary and Secondary displays when a project had "Always ask the IdP to re-authenticate users by default" and "Automatically redirect users to the IdP if authentication is required" enabled in Project Properties. Only the designated Primary display now prompts for authentication.
Perspective
IGN-18664: Backport: Alarm Status Table: Acknowledging previously acknowledged alarms produces a warning message in the logs
Fixed an issue where acknowledging a selection of alarms in the Alarm Status Table that included already-acknowledged alarms would produce a "Failed to acknowledge selected alarm" error on the component and a misleading "An alarm could not be acknowledged. It may no longer be registered" warning in the gateway logs.
IGN-18087: Backport: "Unable to send updates to client" repeated in logs
Fixed an issue with the Perspective Session lifecycle that caused repeated errors in the logs.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261030
Perspective
Perspective
IGN-18631: Backport to 8.1 Perspective: Accordion header is not translated
Fixed an issue where the accordion header did not allow for translation
Nightly Changelog: 8.1.56-SNAPSHOT-b20261106
Alarming
Alarm Status
IGN-17137: Backport: Acknowledging Invalid AlarmID with Remote Tag Providers on Both Sides of Connection Causes Infinite Loop
Fixed an issue where acknowledging an alarm that could not be found flooded the Gateway Network with acknowledge requests and caused remote tags to stop updating.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261110
Gateway Network
Gateway Network
IGN-17705: Backport: Redundancy: Sync timeout set in Redundancy sync does not get respected after Gateway Restart
Fixed an issue where redundancy sync timeout wouldn't apply properly after a gateway restart
Nightly Changelog: 8.1.56-SNAPSHOT-b20261118
Perspective
Perspective
IGN-18939: Backport: Perspective Custom Session properties disappearing
Fixed an issue where saving a project in the Designer could overwrite Perspective Session Properties with an empty configuration.
Gateway Network
EAM & Redundancy
IGN-16928: EAM Remote Upgrade 8.1 -> 8.3 Does Not Work AARCH64
EAM Remote Upgrades for Linux ARM64 and MacOS can now proceed from 8.1 to 8.3
The backport for IGN-18939 - I don't see a similar item in the 8.3 changelogs.. Is that a backport from 2027 that is going to show up in the 8.3 line soon?
The 8.3 ticket for the Perspective Custom Session Props Disappearing issue (IGN-12538) is targeting the 8.3.11 release.
I think that made it into the 8.3.11-rc1 that went out at the start of this week. It merged in at the end of October. So one should be able to kick the tires now.
... Oh and 8.3.12-SNAPSHOT (nightly), forgot that this is a Nightly thread after all.
Nightly Changelog: 8.1.56-SNAPSHOT-b20261120
Infrastructure
Java - Azul
IGN-18501: Bump JavaFX to the October 2026 17.0.x release in 8.1
Updated JavaFX in the launchers and installers from 17.0.18 to 17.0.21, which includes the JavaFX security fixes released since 17.0.18.
IGN-18498: Bump to CSPU release 17.0.21.1 in 8.1
Updated the bundled Java runtime from 17.0.19 to 17.0.21.1, which includes the Java security updates released since 17.0.19 and addresses a number of CVEs. The runtime no longer trusts the eMudhra emSign Root CA - G1, emSign Root CA - G2, and emSign ECC Root CA - G3 root certificates or the Comodo AAA Certificate Services root certificate.
